imito mx1 no signal to tv?
i have a imito mx1 ive just received a week or so ago. i have upgraded it as well as rooted it.Every time i unplug it from power source then attemp to plug it back up say in a different room or tv in my home the tv shows no signal. ive sent a email to geekbuying were i purchased it and all they told me was to upgrade the firmware which i did. but still have the same problem.only way it works is when i let sit off any connection for a couple hours then plug it into any tv and it works. what can i do to solve this from happening. thanks in advance forum.Tags: None
My bet is power supply issues... All of these sticks have CHEAP power supplies. Get a good 2 amp minimum PS and see if it works.
Originally posted by Finless View PostMy bet is power supply issues... All of these sticks have CHEAP power supplies. Get a good 2 amp minimum PS and see if it works.
Same
I have the same problem on imito qx1. were you able to figure it out? should I just return the device?
Originally posted by robbdeeze View PostSo I've tried a new power plug and a different HDMI cable and it still doesn't work. The only way work is if its disconnected for a while being connected back to the television then it seems to work.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
There are currently 1868 users online. 0 members and 1868 guests.
