MK808 Finless 1.5a Ethernet USB issue
I have the ethernet USB device working. It can mount cifs and access my network. Unfortunately it won't update DNS, so it doesn't load any internet sites. I go to force it to have a static IP, cut the ROM doesn't have an OKAY or ACCEPT buttont to save the changes once you make them. Is there an INI or CONF or XML or etc file somewhere on the ROM I can edit to force IP settings?Tags: None
I do not have an ethernet dongle to test this on but I will say unless you have the subnet mask right even Windows 7 wont let you click OK. So please double check that your setting the gateway, subnet mask, and DNS servers correctly.
I have been working with a guy on another problem for a KO module for an unsupported USB Enet device and he has no porblem settings static IP.
There are currently 2529 users online. 1 members and 2528 guests.
