i have stumbled on an issue with overheating,
when using navix in xbmc,when i dl the file instead of streaming,
it heats up the unit very hot,almost too hot to touch,
this is saving the file to usb or micro sd,have not tried dl to unit itself.
it has shut itself down due to heat,
it dosent seem to get hot with any other uses,
will try to save a file to mk808 and see if it heats up too,
just figured i would tell you guys and gals.
BootlegGreg
