iMito MX1 Wifi Issues
I know i'm not the only one but has anyone found a good way to fix the wifi issues with the iMito MX1? Wether it be hardware related (i can solder with the best of them) or even an add-on part like ethernet adapter. Anything would be nice at this point. I also have a MK802-3 i am going to try messing with this afternoon to see if it has the same problems.Tags: None
Originally posted by jwm2 View PostI know i'm not the only one but has anyone found a good way to fix the wifi issues with the iMito MX1? Wether it be hardware related (i can solder with the best of them) or even an add-on part like ethernet adapter. Anything would be nice at this point. I also have a MK802-3 i am going to try messing with this afternoon to see if it has the same problems.
Some folks on the MK808 have reported success with the cheap GMYLE WLAN 150mbps adapters after adding drivers to their devices, but I don't know if it's compatible with the MX1. Any knowledgeable folks like Finless or deadHP1 know if that's a possibility with the MX1? I thought I read something that the WiFi files are setup differently on the MX1. The instructions for the 808 are as follows.
1) copy rtl8192cu.ko to /system/lib/modules after you have mounted with rw (I usually run ESexplorer with root options)
2) rename /system/lib/modules/rkwifi.ko -> /system/lib/modules/rkwifi.ko.old in case you need that later
3) rename /system/lib/modules/rtl8192cu.ko -> /system/lib/modules/rkwifi.ko
4) fix permissions, I do that from terminal, but I think you can do that from ESExplorer as well
chmod go+r /system/lib/modules/rtl8192cu.ko
chown root:root /system/lib/modules/rtl8192cu.ko
There are currently 2392 users online. 6 members and 2386 guests.
