Help with craig cmp745e
I recently purchased the craig cmp745e, a 10.1" tablet running a rk29sdk. After playing with it for a couple days I was able to root it. Now I'm trying to flash a new rom and have gotten stuck. I cant install any drivers on my win 7 32bit notebook and rktools doesnt see my tablet. I am able to get into recovery but thats as far as I get. Any ideas? -
What did you do for these instructions?- (3) Turn Mass Storage OFF
- (4) Enable "USB DEBUGGING" from Developer Options
- (5) Enable "UNKNOWN SOURCES" from Security
"Unknown Sources" is checked by default on my tab, but I can't find any settings for Mass Storage support or anything resembling "Developer Options."
Re: Help with craig cmp745e
Well that gets a little tricky. I had been able to find a gapps.zip file, I think it was in a Polaroid forum, so I had the older android market. You can probably find apps on the net but there are some out there that will toggle debugging mode, one you install the apk you will get your developer options. Mass storage I didn't turn on so I didn't have to turn it off, just don't turn USB mode on when you connect it to your computer.
Sent from my HTC PH39100 using Tapatalk 2
It is possible to get the info, I got a copy of the kernel from a different source. I've tried a JB rom but couldn't get the touch screen to work, it did load though. I made an online nandroid backup and was able to restore my tab after the failed attempt. It wasn't a total loss though, I now have cwm!
Sent from my CMP745E using Tapatalk 2
jc73, I followed your suggestion and successfully got Market access for my Craig. I did some googling and found the gapps.zip file on this blog entry: http://www.the-digital-reader.com/20...roid-pmid702c/ . However, I'm not sure what you meant here:You can probably find apps on the net but there are some out there that will toggle debugging mode, one you install the apk you will get your developer options.
Hello,
Please make a Rom Dump, look at here --> http://www.freaktab.com/showthread.p...sing-ADB-guide.
As i see on your Photo´s you got a Rk29xx Platform, so i think we can ran Jelly Bean.
Rainer
Successfully rooted my tablet. Thanks for the help.Last edited by panda_boner; 01 December 2012, 08:53.
There are currently 2767 users online. 0 members and 2767 guests.
