Big Thanks to my US Friend, we are finally working out a real 1080p firmware for MK808, here is the firmware download link: https://docs.google.com/a/geekbuying.com/file/d/0B2J_Nqv8IludekdMVFczelo2VUk/edit or http://ultramegabit.com/file/details/VD8VMvohPUU Firmware update method, you can check here: https://blog.geekbuying.com/index.php/2012/09/28/mk808-mini-pc-new-factory-firmware-release/ and here is some screenshot after you flash: In this Version, the CPU will be set to 1.4Ghz, it […]
Seems allright Ethernet very stable, playing 1080p from youtube.. but a bit slow and laggy. CPU is set to 1.4Ghz,
