Mk 808 loading loading loading but ....
    First of all, greetings to all.
    I'm sorry for my english. I'll try to explain my trouble here:
    I've bought mk 808 on geekbuing… for 4-5 days it works good but yesterday, after a crash of playstore, i've turned off the key tv and after that the key has stopped in the booting screen ( when appear the "android" logo).
    how can I fix it?
    this is my situation:
    on top-sx there is the psu
    then there is my configuration, whitout micro-sd or hdd
    then the screen when mk stops,
    and then there is the logo of reset mode...after that ( 1 minute) the system reboots and stops.
    I tried to use moborobo but I can't put mk in debug mode because it stops on screen of boot!
    Tnx to all
    That lay down Android man with the red symbol means your ROM got corrupt. You will need to flash a ROM to fix it.
      Yes I know.. But how?? I can't acces at debug mode and Windows can't recognizes the key-tv... Tnx
        Very simply - for flash better use flashing tools /see thread about mk808 finless rom 1.5A / ,download and unzip software into computer,then use paper clip for resetting your MK808 /without power!/,hold down reset button and connect MK808 to computer /usb cable must be connected into OTG port-NOT USB-MK808// If computer say "found new hardware...",release reset button , install drivers and flash to Finless 1.5A-this Rom is very amazing and stable /for details,read instrucions into text file/. Because original Rom is very unstable and have bugs /fragmented , unstable synchro A/V etc../ is normally,when you MK with this Rom crashed after few hours....I has same problem - Finless rom is very good..GoodLuck!
        PS- reset buton is available until think hole on side MK808 without logo
          Originally posted by prokji View Post
          Very simply - for flash better use flashing tools /see thread about mk808 finless rom 1.5A / ,download and unzip software into computer,then use paper clip for resetting your MK808 ,hold reset button and connect MK808 to computer /usb/ If computer say "found new hardware...",release reset button , install drivers and flash to Finless 1.5A-this Rom is very amazing and stable /for details,read instrucions into text file/.
          Ok, but for me the problem is to istall driver of mk808 because I can't put mk in debug mode!!!!
            You dont need debug mode. You put it into flash mode using reset button and USB cable. In my ROm are full instructions.
              Thank you very very much!
              Now my mk808 works!!!
