ROM U30GT H 1.09 900supersport 1.08 (266 mb)
The ROM installs as normal.
- Uncompress the archive
- remove any sdcard
- put your cube into flash mode
- connect to the PC
- start the ROM tool
- Erase IDB
- Flash
First boot will take you into a touch based clockwork recovery. Reboot from here and the cube should boot normally. You will probably find on the first full boot you are warned about the internal storage being faulty, press this and format and you should be good.
Within the ROM kit is
- the kernel from 1.06 used only for recovery
- touch based clockwork recovery
- stock boot.img with embedded kernel from 1.09
- system rooted, debloated, market fix
- 2 gig user space for apps
As usual thanks go to the team here at freaktab, I couldn't do this without the support on this site and a special thanks to Cel1971 for his willingness to take on the role of tester for this ROM.
Enjoy
