Uhost 2 is the improved version of Uhost, it comes with Android 4.0.4 ICS(is about to upgrade to Android 4.1 soon) Rockchip RK3066 Dual core 1.6 CPU and Quad Core GPU,it also features built-in bluetooth,support skype,XBMC,Netflix.
Comparing with other android mini PC, UHOST 2 use the different launcher, so you can change the launcher easily by yourself. What’s more,it supports to power off the device in the menu.(This is the only one which has this function in dual core mini pc). And it add a function called” hide status bar” on setting menu.
Source:
Product Information:
What’s in the box?
1 x Uhost 2 Dual Core TV Box
1 x AC Charger (US type)
1 x HDMI Cable
1 x USB Cable
1 x User’s Manual
1 x HDMI Cable
1 x USB Cable
1 x User’s Manual
