How to modify the key of gamepad or joystick
Originally posted by jason1 View PostHi,guys ,I'v a wired joystick ,it works ,but how to modify the key on my MK802 III,thanks
I'm using 2dark4u/Finless custom ROM version 1.7 on a UG802 and it's working fine with a trust GXT30 wich is a wireless joystick with a usb receptor.
Greetings.
Also, I have no problems using gamepad and remaping buttons but I can't use it in 3d games like The Dark Knight or NFS Most Wanted. I think they don't have implementation for a gamepad so I was planning to use USB/BT Joystick Center to emulate screen touches. But when I try to start Joy2Touch Server it fails because it can't detect any touchscreen.
Has anyone played The Dark Knight or NFS Most Wanted with a usb gamepad?
Maybe Finless or 2dark4u can bring some light to this, maybe simulated touchscreen can be implemented, don't know...
Tried to download Joystickcenter from Play store, but could not, it tells not compatible wit device.Could you help me out?
Originally posted by pigster View PostHow did you get it working? I have an 802 III too, tried to play shadowgun witha wired xbox controller for windows. The round Xbox button flashes green, but nothing happens, game does not recognise controller.
Originally posted by hammondb4 View PostAlso, I have no problems using gamepad and remaping buttons but I can't use it in 3d games like The Dark Knight or NFS Most Wanted. I think they don't have implementation for a gamepad so I was planning to use USB/BT Joystick Center to emulate screen touches. But when I try to start Joy2Touch Server it fails because it can't detect any touchscreen.
You guys just need the joy2touch addon for usb bt joystick center 6
With this Joy2Touch Server you can emulate Touch-Events and Mouse-Events with your Joystick, Keyboard and Mouse. So you can play Touch-Only games with your Keyboard and Mouse or with a Joystick.
I guess that this will have to be something you need to ask the developer of joystick center 6 then.
Edit 2: Here's a post of the dev saying that he's going to get some android sticks and add support for them
There are currently 2100 users online. 0 members and 2100 guests.
