Has anyone been able to figure out what is the cause of this and if it can be fixed?
MK808 horrific with Netflix
Otherwise this little gadget seems to work really nicely with a 55" full-hd tv but Netflix, the main reason i bought the device, is practically unwatchable. The picture stutters so badly no matter what the settings are, so i had to go back to plugging my laptop with the tv to watch movies.
Has anyone been able to figure out what is the cause of this and if it can be fixed? -
Ok, the 480p solves the question of why the picture was so soft. I thought that maybe the internet connection was too slow to achieve a better picture quality but it is a limitation of the app itself. The scaling possibility came also in my mind. Could that be a problem with the Netflix app or the device?
I'm not having this issue with my MK808 running the Finless 1.5a ROM, however I did have the problem with choppy image with Netflix on my old MK802II. The reason for this was that there was too many apps still running in the background, which I solved by using https://play.google.com/store/apps/d...tes.fastreboot to free up memory.
Here is a link to a HD Netflix APK on xda-developersTV Stick: MK808 // Tronsmart T428
ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
Recovery: ClockworkMod
Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
Phone: Samsung Galaxy Note II
ROM: Whompasaurus v4.2
Kernel: Persus
The stuttering you are referring to is a low framerate. Netflix for mobile does three things to cut down on the data transfer. One they limit to 480p on all devices except two. Then they limit the bitrate a bit to keep the flow going better. The other is they lower the FR to 20FPS which cuts out a lot of frames. Movies are 24 FPS and TV shows are 30 FPS. Dropping these to 20 FPS causes a hiccuping effect in motion sequences. Now if you are getting really super bad two to three seconds worth of stuttering then that is another issue. But if you are referring to the small consistent skipping, especially during panning of the camera or large object rolling by, then that is due to the FR being dropped.
Originally posted by reddragon72 View PostThe stuttering you are referring to is a low framerate. Netflix for mobile does three things to cut down on the data transfer. One they limit to 480p on all devices except two. Then they limit the bitrate a bit to keep the flow going better. The other is they lower the FR to 20FPS which cuts out a lot of frames. Movies are 24 FPS and TV shows are 30 FPS. Dropping these to 20 FPS causes a hiccuping effect in motion sequences. Now if you are getting really super bad two to three seconds worth of stuttering then that is another issue. But if you are referring to the small consistent skipping, especially during panning of the camera or large object rolling by, then that is due to the FR being dropped.
NetFlix
Netflix doesn't want you to stream high quality movies to android devices for this exact reason, because we can stream them to TV's! It's the same reason you can't watch free hulu on your android you have to get plus, it's a different licensing agreement with the makers of TV and movies, they know nobody wants to sit at a computer to watch tv and movies, so they made it free for those guys.
Originally posted by Broman View PostNetflix doesn't want you to stream high quality movies to android devices for this exact reason, because we can stream them to TV's! It's the same reason you can't watch free hulu on your android you have to get plus, it's a different licensing agreement with the makers of TV and movies, they know nobody wants to sit at a computer to watch tv and movies, so they made it free for those guys.
Netflix app is on Samsung Tv´s, PS3, Xbox and many more
As long as u pay the monthly fee they dont care if you stream it to your bathtub...
Any way. The Netflix app is ok on tv but. The subtitles are way to small..?
And it skips frames. Very notable.
I read that have now made netflix available for linux..
Could this mean we soon might be able to access Netflix true our browser for real HD ?
I have found that stuttering picture can also be linked to poor wifi connection. Here is what I have noticed with NetFlix on my mk808 with finless 1.5a and Kizs 720p kernel: every time picture quality changes from better to worse or vice versa (pixelated to less pixelated and the other around), there's some frameskip. If your wifi connection is such that you're constantly switching between brief periods of decent picture and then periods of poor resolution, there is going to be a lot of frameskip in between. So a lot of skipping problems can be alleviated by addressing the internet connection of the 808, and there are a ton of posts of this forum and on armtvtech.com that can help you with that.
There are currently 2902 users online. 5 members and 2897 guests.
