i would like to have this rom if anyone can upload it,
i had 4.1.1 on it when it arrived,but i have some freezing issues,
at 1st i thought it was just on xbmc,but then it happened on the video player from avi,
i replaced the hdmi with a higher quality cable in case it was just an output issue.
but either way,would like to have the option if possible.
thanks,
BLG
