mk808 acting wierd help please
    not sure what happened i left the room came back tv was off i turned tv back on and mk808 is very unresponcive i clicked my reboot app and it went to a black screen
    nothing will install from google play
    most of the time i try to open an app or long hold on home screen it does nothing sometimes im able to get stuff to open. this is happing on both home screens.
    widgits like music reboot app and wether just say loading i can get into settings sometimes.
    its like android isent fully loading
    the tv stick its self isent hot i
    iv unpluged it a bunch of times sometimes it works better sometimes nothing works
    just happened an hour ago
    oh and im not sure what rom im using
    last thing i was doing was i updated the binary for supersu and in app i clicked change to superuser
    on google play when trying to uninstall or install or update something the blue bar just goes and goes and goes
    the hide bar app isent showing up in notficatsions i even tryied using google play on pc to send an app to the mk808 and still nothing
    another weird thing every time i restart it some thing new says its updating sometime its the same apps its like every app i have is updating at once
      well clock was frozen for about 10 minutes i ran fast reboot and the time went back to normal no its froze again movting from tab to tab still works i just cant open apps took xbmc almost 30 minutes to open and when it did the screen went red and crashed the whole stick what the hell is going on
        well i finaly got it to work i was finaly able to close some processes like rkupdate and some other stuff which helped a little the real problems was google play some how almost all of my apps were trying to update at the same time some were apps that were set to not auto update i was able to get into google play i went to where all my apps show in the app and stoped every one after my mk808 is perfect xbmc is running a little slow but im happy every thing is working
