UG802 finless 1.6 to 1.7. Can't overcome "No Found RKAndroid rock USB"
    Hi all , to demonstrate I'm on finless 1.6 shows I have successfully done a PC usb flash of my UG802 before.
    I recall the fun & games was when I was trying to trigger the usb mode. I've definately set usb debugging mode and my pc sees the rockchip drive ok.
    But no matter I do, I can't get the finless flashtool to find the device :-(
    The 1.6 rom doesn't have an 'advanced settings' view.
    So....any clues to get me to the next step.
    Although I've not reached the point yet..I don't intend to add heatsinks etc, so just want the fastest available rom for unmodded devices. When I'm confronted with the option...what should I choose?
    Thx
    reboot to bootloader
      ah ha!
      yep I'm in.
      1.7 looks coolio, can't see how the UG802 can get much better now ( just wish I can solve my Lan issue with my ky-rd9700 device )
        Re: UG802 finless 1.6 to 1.7. Can't overcome "No Found RKAndroid rock USB"
        Blue tooth support and touch screen emulation would make it that much better
        Sent from my Galaxy S too!
          Bluetooth may come soon but you can get droidmote and control it from your phone with full touch screen and music controls etc
