Is it possible to fix it?
Help! Bricked UG802 after flashing the finless 1.7 rom
Hi all,
I'm exactly in this situation an tried at least 10 times the indicated procedure, but it doesn't work.
It keeps me saying "Check chip fail" (see image below).
Any suggestion?
I suspect I'm using a wrong update.img image, can you please point me to a link where to download an update.img taht works for this procedure (or possibly the original firmware)?
Thank You very much!!!
Any suggestion?
Yes, but tried also update...
I don't remember which update.img I used (I tried different, one for sure teh finless 1.4a)
Don't know if it could have something to do with the update.img used, so if someone could point to a link of an update.img surely working we can start to eleminate soem ipotheis.
Thank you
Marco
EDIT: found the link I need in your signature, now I'll test.....
EDIT 2: OK, used RockChip tool and update.img found following the link on your signature and all worked perfectly THANK YOU!
EDIT3: looking again at the screenshot I posted it seems clear the problem. If I'm not wrong the image I used was compatible with RK29 chip instead of RK30. Thank you againg for you precious link contained in your signature!Last edited by marcocale; 29 January 2013, 10:32.
There are currently 2100 users online. 3 members and 2097 guests.
