MK808 Hybryd FW (Minix X5 Mod + kzis 1.51Gh +Root) MK808
    wheres the one click tab in android tuner? i cannot find it.. i downloaded the free version..do i have to find the pro version?
    EDIT: its under App Magr.. i found it, but then again i cannot find oneclickoptimization.. nor any other setting you say..
    are u sure the app is https://play.google.com/store/apps/details?id=ccc71.at ?
    EDIT 2: Found some, their path is different than how u r describing it
      Originally posted by lewy20041 View Post
      its plug and play for android
      Thanx sure gonna try this item
      I,m also install your rom 4 hours ago
      And till now wifi didnt drop not even one time
      (65mbps)
      Damn good job thanx
        also on android task manager settings i cannot find
        "startup kill" and "delay"
        also on android tuner theres no option to boost apps or DB
        can u please provide more details click by click instructions for both programs again. thank you
          ups. i have pro version
          Everything is possible if we work together!
          ApkFreak
            i have both pro versions. wen i ill have some morr free time i will look into it
            ApkFreak
              Thanks for this awesome FW. It is way more smoother and stable than 1.5a. Did not get a soft reboot yet, and WIFI never dropped.
              I am using the 1080p kernel, and it is still very fast... Antutu scored 8900. Videos are smooth.
              Couple issues I'm having though:
              1. Cannot install Amazon app in Play Store. It says not compatible with this device.
              2. If I use browser to visit www.youtube.com the browser crashes to desktop. And with Youtube app there is no full screen button anymore.
              3. Cannot install Xperience 1080p skin in XBMC, after following your HW accel guide on XBMC. (MKV Videos play fine in HW+)
              4. In XBMC when I play video through MX Player, it seems like the autohide task bar is constantly trying to hide, whenever I want to click on any of the controls. So the menu disappears right away.
              5. I tried connecting my Linksys USB 100TX dongle, and it sees my Mac address. But I cannot get a connection at all.
                for youtube just install the apk from my first post there is fullscreen option.
                about mx i saw that to and i will see what i can do about it
                for amazoj you can install this apk https://www.amazon.com/appstorelanding
                as to xbmc what do you mean by you cant install xperience1080? more details please
                ApkFreak
                  Thanks lewy for the suggestions. I will try the amazon and youtube apps.
                  Was thinking maybe the Chrome Browser wont crash, will try that too. Can you show me where to get a working driver for my USB100TX dongle?
                  Also about the Xperience 1080 skin, when I try to install it, I get the "Dependencies not met" error in XBMC.
                  Thanks!
                    Thanks!
                    hm. you can download it from https://github.com/Black09/Xperience1080 as zip. unpack it an put to sdcard>android>data>org.xbmc.xbmc>files>.xbmc>addo ns
                    ApkFreak
                      lewy i have the same problem with xperience skin..do i need to have the 1080p kernel installed or no?
                      also i managed to play a 1080p movie with xbmc but its laggy compared to normal dlna play by mk808 media player or mxplayer playing directlyfrom nas. how do u play your movies?
                      btw mk808 media player seems to be the fastest of all but does not show subs.. do u know if theres something that can be done?
                        lewy why i have only the path:
                        sdcard>android>data>org.xbmc.xbmc>files ???
                        theres no >.xbmc>addons
                        or /.xbmc/userdata , after sdcard/android/data/org.xbmc.xbmc/files/
                        also i have the same problem with xperience skin..do i need to have the 1080p kernel installed or no?
                        ferst for krnel. NO. xperience 1080 skin is not karnel related
                        for .xbmc folder download es file menager from google play go to settings and set it to zhow hiden files
                        ApkFreak
                          how to flash
                          How do I flash this rom? No instructions on how to partition, no readme. I checked all other roms threads hoping to find any instructions there but I couldn't find any in any threads as they all say that the instructions are in readme. This rom doesn't have one.
                            lewy20041 do u manage to stream 1080p 100% smoothly with xbmc?
                            which media player u think is the fastest for our device and rom?
                              hi
                              Bsplayer notwork also working 4 second shootdown all system
                              Flash player not working write update flash player not open
                                still broken.. dependencies do not met..
                                any other advice? :/
