PMID705X
Originally posted by DriGGster View PostAnyone have any luck/ experience modding or installing google play store on this device.
Image link: https://www.dropbox.com/s/pq4r92u69jsck0y/PMID705X.img
P.S. for someone who wants it so badly, you sure aren't exactly killing yourself testing itLast edited by elektrik; 11 December 2012, 21:30.
Would this post be in reference to the Polaroid PMID705 (non 'x')? I just bought 2 from BigLots for $69 each and was wondering if it could be rooted. I have searched tirelessly on the matter to no avail. I keep coming up with every other variation EXCEPT the 705. Any info would be greatly appreciated.
Thanks in advance!!
pmid705
Originally posted by McGee82 View PostWould this post be in reference to the Polaroid PMID705 (non 'x')? I just bought 2 from BigLots for $69 each and was wondering if it could be rooted. I have searched tirelessly on the matter to no avail. I keep coming up with every other variation EXCEPT the 705. Any info would be greatly appreciated.
Thanks in advance!!
Originally posted by louisalmaguer View Postiinsalled market and then root checker which verified root access, also got terminal emulator and set tablet to set external sdcard for app installation and save internal storage space , another cool thing is the fact that it will connect to adhoc network on my iphone
Pmid705 installing market
Originally posted by McGee82 View PostThis all sounds awesome! Care to share how you did it?
I followed the instructions (1-3) in this thread
http://www.freaktab.com/showthread.p...light=pmid4311 for installing the market and android terminal, you might want to also grab root checker just to be sure it is rooted if you want confirmation on whether it is rooted or not,
after you install terminal, to set apps to move or install to external sd :
open terminal up and type "pm setinstalllocation2" and you should be there if you get a message with three options it will tell you what to type with a number after, it will look something like this on the first line 'pm set-install-location' then you'll see the options with numbers (0 1 2) next to them
so you would type 'pm set-install-location 2 ' 2 being the option to install to external sd
then you will want to go to app manager and click on each app you will see the option to move to sd card , some apps which are loaded by default from firmware will not have the option, market will not have the option either, but most of the others will, good luck
Originally posted by louisalmaguer View PostI followed the instructions (1-3) in this thread
Thanks soooo much for this!! I will definitely be trying this as these are going to be Christmas gifts. I will let you know how it all works out. Once again, thanks for the time and explanation.
There are currently 2531 users online. 4 members and 2527 guests.
