[BACKUP SERVER]Modifed Polaroid Stock/Custom ROM Live Suite Image links
    NEW!!
    • PTAB7XC Modified Stock:
    • PMID4311 Modified Stock:
    • PMID701I Version 13 ONLY ([ICS][STABLE]Elektricity v0.2):
    • PMID701I Version 10 ONLY ([ICS][STABLE]Elektricity v0.2 ICE CREAM SANDWICH):
    • PMID701C/PMID701I-X10 ONLY ([GB][STABLE]Elektricity v0.2 GINGERBREAD):
    STABLE
    • PMID701C/PMID701I-X10 ONLY([ICS][STABLE]Elektricity v0.2 ICE CREAM SANDWICH):
    • PMID703C/PTAB7XC([ICS] Modified Stock-See notes in original thread):
    UPDATED
    • PMID705X ([EXPERIMENTAL][ICS] Modified Stock-NEED USERS TO TEST!!):
    EXPERIMENTAL
    • PMID10C ([EXPERIMENTAL][ICS] Modified Stock-NEED USERS TO TEST!!):
    OLDER
    • PMID701I Version 10 ONLY ([ICS][STABLE]Elektricity v0.1):
    https://public.bay.livefilestore.com...ion.png?psid=1
    Test Posts To...
    1st!
    So now that i finally have this down loaded, (s3 sprint wifi tether non 4g) what do i do with it? Do i have to extract it and adb the thing?
    Thanks button depressed"beer"
      Test Posts To...
      Originally posted by jr71x1978 View Post
      1st!
      Could you be more specific? I've listed 6 devices and have no idea which one you're talking about lol!
      As for what to do with it, they're all Live Suite Images, so if you don't know how to flash your Polaroid, I'd head over to http://southerntelecom.com/polaroidsupport/
        Gotcha and yeah it's the pmid10c and yeah, i'm only used to flashing tar and zip files but the problem i'm running into is that when i look at the file .img it is 319MB it doesn't see it like this other .img ota manufacturers file. When i go to that file i can extract and open the live suite, maybe it's a bad download, i'll try it again, no worries, i am a noob again:-o
          Download link not working for me.
          I am trying to download the PMID701C image but when I click the link I see the message below.
          "This XML file does not appear to have any style information associated with it. The document tree is shown below.
          <tree>
          <message type="SUCCESS"/>
          <require_auth/>
          </tree>"
          Can you tell me what I need to do to download the image?
            <tree>
            <require_auth/>
            </tree>"
            I'll double check the links. they worked before :-(
            UPDATE: I've fixed the links. Give her a try again! Sorry about that!
              You're correct. If you're used to flashing (I'm guessing an android phone) the Live Suite application/drivers take a little getting used to. I actually prefer it this way, at least for the tablets (I've had a heckofatime trying to get a signed update.zip to flash on a stock recovery (I'm somewhat new to this so I am beginning to think it's not possible, so if you know someone who can 'learn me' feel free, lol!). If you look on my link in the Polaroid forum under my elektricity ROM I posted the link where to get the Live Suite application. Let me know if you need any further assistance.
                It worked perfectly
                Thank you for fixing the links and also your work on creating this image.
                Regards
                  Regards
                  Sure! Keep in mind it's in 'experimental' state since I don't have this device. I would greatly appreciate your feedback though to see if this ROM works.
                    I am testing this out now I will report back if i see issues and what not
                      Ok cool. Anxious to know if it works...
                        It worked perfectly on my 701c. I had previously updated to the official ICS package if that helps any.
                        I found this ROM and loaded it because I was unable to get the Google Play store working under the official ROM. The latest version 3.10.9 loaded just fine installing the apk from SD.
                          I'm assuming you meant elektricity ROM (I hope you flashed that one! ha ha!).
                          Glad it works so well for you. Working hard on V0.2
                            Yep, I'm using version 0.1 of your elekricity ROM and have nothing but good things to say about it. Thanks for your hard work!
                            Is v0.2 based on Jelly Bean?
                              thanks! re: v0.2-not per say. it'll start with ics. there is demand for an elektricity gingerbread version, so that will be thext flavor of v 0.2 and then I'll play with jellybean....
