The graphics were lifted from many sources and are freely shared for other devices... some from Cm9/10 themes and I will endeavour to contact those who made them and give thanks...
I have lovingly resized literally hundreds of .png files for our MDPI resolution devices and modded fully decompiled:
>>> framework-res.apk
>>> SystemUI.apk
>>> Browser.apk
NOTE!!
I based this on SuperSport stock based V1.10 system files so is tested with this ROM ONLY... HOWEVER...
It SHOULD work fine on any other STOCK based ROM using the same Official CUBE V1.10 based firmware (latest)
NOTE!! This does NOT INCLUDE decontaminate V3 as that ROM is actually based on the firmware from a different device and the frameworks and files are different... It MAY work but no guarantees.
>>> Theme CWM zip Download: http://db.tt/Dq4mkfcC
>>> UNDO CWM zip (Restore stock files) Download: http://db.tt/IX3yJHHv
****SUMMARY:
> This is a RED them for the CUBE U30GT-H running firmware based on V1.10 official (latest)
> IT MAY work on other Roms just fine but YOU will have to test this and tell me!
> For testing on other ROM types make your own restore zip first. Simply unzip,replace the apk files in the one I have provided with the corresponding files from your ROM and zip it up with any root file manager
ENJOY!!
Sent from my U30GT-H using Tapatalk 2
