Arnova 7G2 EXT4 Full Root - Market - 3G - NTFS Support - Bluetooth - Openvpn - CIFS -
    Arnova 7G2 EXT4
    Full Root - Market - 3G - NTFS Support - Bluetooth (USB Dugle)- Openvpn - CIFS -
    External Installed APK
    • Bluetooth File Transfer
    • Bluetooth GPS Provider
    • Bluetooth on/off widget
    • Color Notepad
    • Cfs Manager
    • Titanium Backup
    • GScriptLite
    • Openvpn Settings
    • Superuser
    • Market
    Full EXT4 Support
    Increased file system app to 680 MB free
    200 MB free RAM after first flash
    After first flash boot in 15 Seconds
    Market Configuration:
    Start the Market, configure your google account and login.
    If you should see a few apps, exit to the market, go to settings, applications, manage applications, click on "All" tab, select Market and delete Market Data.
    3G
    Complete support with USB OTG for Hauwei 3G key models E1550 E1692 E1750 E1820
    NTFS Support
    I made the necessary changes in order to see external drives formatted with NTFS file system.
    Mount NTFS disk – what to do:
    Automatically at boot time the system will create a folder called win inside the mount point /mnt
    Run GScript and add a new script, call it – mount-ntfs -
    Enter the following command: /system/bin/ntfs-3g /dev/block/sda1 /mnt/win
    Save
    Connect via usb otg the disk, start the script and entire contents of the disk will appear in /mnt/win
    I did a test with a 1TB drive with my mkv and I was able to see to 1080p without any problems.
    To umount the disk, create a new script, call it umount-ntfs and enter the following command:
    /system/xbin/umount /mnt/win
    Save
    WARNING:
    During umount, all applications that are taking up the mount point /mnt/win SHOULD BE CLOSED.
    If you do not, the script does not umount the disk and if the disconnected abruptly, you may lose data.
    Bluetooth
    Entered all necessary kernel modules to support external USB Bluetooth to connect to the USB OTG cable.
    Obviously the Android drivers are a bit limited, look on the various forums to see what sticks are compatible.
    Of course, Bluetooth file transfer has been included to turn off and turn on and manage the Bluetooth
    CIFS support
    Added kernel modules in order to see share external network via the CIFS protocol
    Full support for OpenVPN
    Added kernel module tun.ko to use encrypted connections with OpenVPN server.
    Further changes:
    Inside /system/xbin directory has been added to the latest version of busybox
    The openvpn binary was always placed within this directory.
    All kernel modules are loaded at boot time
    Bugs
    Bluetooth
    When the Bluetooth is on and the display goes to time out, the internal POWER signal is sent to tablet
    ROM -> Firmware_Arnova_7G2_V3 ROM by Fenice57 (129 megabytes)
    Awesome Fenice! I want that stuff on my 10 G2 but you are the master when it comes to adding drivers and editing the system. Far better than I.
    If you get a chance to do one for the other G2 tabs let me know and I will test for you!
      Each his own
        Welcome Fenise!
        Thank you for having your rom on here, great work
        </form>
          Fenice, EXT4 is cool and all but take a look at yaffs! It is made for NAND memory and is a better file system than EXT4 for tablets with NAND memory. I will be working on that soon
            New Update – Only boot and recovery system
            IMPORTANT:
            If you take this update, after flash new system recovery will start on boot and delete your data.
            Take a backup
            Remove your SD Card or all data will be lost
            Whats New
            Best performans and I/O improvement
            I 've used HOTO Benchmark before and after update, see jpg
            Before After
ID:	428729Click image for larger version
            ROM -> New Boot and Recovery System by Fenice (9 megabytes)
              Hi Fenice
              At AN7G2 working WiFi in Ad-hoc mode with connect to the USB-adapter?
              I'm on AN8G2 no device detects Ad-hoc.
              Maybe this will help? But I do not know how to do it: (
              Sowa
              Archos 7c HT (My Custom ROM production) -> ARNOVA 8G2 8Gb (My modification MorkaMod JB v.1.2)
              Chinese STAR A5000=>Star N8000 (My Custom ROM production)
                Sorry at the moment no support for Ad-hoc
                  Hi fenice57
                  After trying to install your 3.1 update my device (arnova 7 G2 will not boot. Had to reinstall V3 ?
                  Sorted now. Re Read the post on arctab to not erase IDB
                    Originally posted by duryard View Post
                    Hi fenice57
                    From V2 to V3 you must EraseIDB
                    You can't go from v2 to 3.1 update.
                    From V3 to 3.1 update you don't erase IDB
                      Sorted now thanks. Nice rom
                      How do I boot into recovery please.
                      4 Ext recovery Fc
                      CWM just reboots.
                      Or is it just via adb?
                        The link to fimware is not working, can somebody please reupload it?
                          I just tested and the link works fine.
                          Make sure when you login tyou check the box under login "keep me logged in".
                            How to Install
                            Hi Guys, I have a little problem would like the firmware instalation but I'm not getting the Arch instaled with drivers, it is recognized by the PC even as Qualcomm and once as Android in two I can not get a driver installed no ADB or rock chip I can be one more help. i would so much have this firmware.
                            My device Arnova 7C G2 4GB
                            Operating system on my PC is Windows Vista.
                            ty for help
                            Sorry for bad english
                              Originally posted by fenice57 View Post
                              NTFS Support
                              Save
                              Save
                              WARNING:
                              @Fenice57, Would it possible to use this on the 10G2 (and other models), if it is how can I extract the needed files and install them on the G2, or could you do a pack of some sort.
