UG007 & Magic Trackpad?
    Any one been able to get the UG007 and an Apple Magic Trackpad to work?
    I can get it to connect but it doesn't do a thing. The trackpad works fine with my phone (SGII - Skyrocket)
    When i got the UG007 neither my apple trackpad or keyboard would do anything after being paired. I flashed Finless rom 1.5 and now the keyboard works great but the trackpad doesn't do anything.
    Any help would be appreciated.
    PS: Bob - Finless, thanks for the great work!
    known issue.
    I have the same, and I even flash the original updated ROM - http://www.freaktab.com/showthread.p...ully-supported
    and all the BT devices now working properly, but the magicpad doesn't
    (the good thing is that you can not even pair it...)
    Tomer
      try the app blueinput and see if that works
