Any possible way to root this beast???
    Sorry :-( Tho i hope my Englisch is not to bad for you.
    chmod 755 rkdump
    unable to chmod rkdump: Operation not permitted
    That´s mean you are not root.
    Try to type su and see what happens.
    When you got a error try it with sudo chmod 755 rkdump
    Neomode
      Neomode
      not at all your english is fine.
      using su gives me this
      uid 2000 not allowed to su
        That´s saying me there is no su on your Device.
        Check if the File is there, to do this make this.
        adb shell
        cd /bin
        ls
        take a look if there is su.
        If not Download from here http://downloads.androidsu.com/super...arm-signed.zip
        then do adb push su /bin
        Neomode
        Can we chat over Jabber (Google Talk) ?
        My Name is [email protected]
            adb shell
            cd /bin
            ls
            no su in the list. downloaded file
            unzipped renamed folder to su then place in sdk folder
            is that the correct procedure?
              [QUOTE=tabletbuster;43513]
              adb shell
              cd /bin
              ls
              /QUOTE]
              Yes now push this to your Tab to /system/xbin
                su wont push to system/xbin
                tried to push it sdcard just to see if it would and it did
                I think its going to be a hard nut to crack
                Thanks for your time ans effort
                  It would be easyer if we can do this together via teamviewer.
                  So i can help you to fight the beast down ;-)
                  Neomode
                    Neomode
                    u need an id?
                      Yes please Download the Teamviewer.
                      Then i need your ID and Pass.
                      Thx
                      Neomode
                        Thx
                        Neomode
                        pm
                          This beast is not a RK2918 Device !! It is a Wondermedia Beast !!
