Flash Player has stopped working
    I am on Finless 1.7 (on MK802III) and Flash Player has quit working. It only displays the Get Flash Player button where flash content should be. Of course the page is 404 when I click it.
    I downloaded the last supported Android version from Adobe and uninstalled the current install and re-installed Adobe's last version. It does the same thing.
    Any ideas? Flash Player version is 11.1
    Oh, and it won't work in stock browser and Dolphin as well.
    MK802III Runnin' the Fin v1.7
    I'm running Finless 1.7 on UG802 and the Adobe Flash version is 11.1.115.11_120817. Pevious versions of Flash Player for Android can be downloaded from Adobe:
    Enable plug-ins (stock browser/settings/advanced) needs to be set at "Always on" for it to work for me!
    (On demand works but you have to click on the green arrow to start video).
    I remember Bob having an issue with Flash Player in earlier ROMs so I've never updated.
    Hope this helps/works!
    ...almost forgot...I also have to check "request desktop site" in stock browser settings!
      As you will see in my first post i already downloaded the last supported version from adobe. Got it working in the stock browser.
      The hard part was getting it working in Dolphin. In more>settings it was turned off and wouldn't let me turn on flash player. It would tell me that it is disabled and to set user agent for iphone to get html5 content. LOL ??????? Of course that didn't work.
      Then I found a post on XDA that said to go in to data/data/mobi.geek.TunnyBrowser/shared_prefs with root explorer and delete Browser_preferences.xml.
      That worked and allowed me to enable it.
