MK808 with Bluetooth
    I purchased this MK808 and it suppose to have bluetooth I confirmed with the seller. I couldn't refuse at at $40 dollars. The unit has not arrived yet, but i'm curious to know if i will be able to run Finless ROM on it since its someh what different model because of bluethooth.
    Also another concern I have is since it from an unknown company what if there Android OS has malware or some shady apps? Little worried about signing in with my gmail that has my CC on it.
    Make sure if it is MK808B. For MK808B, when I used Finless ROM 1.5a.... it failed to turn on the wifi. Only when I downloaded the stock firmware for MK808B, the wifi could be turned on.
    I am not very sure about your malware concerns. I have seen and read good reviews for this item, so I trust it would be the genuine. This is my opinion.
      How can i tell if my MK 808 has Blutooth? the back of the box says it "Supports Bluetooth V4.0" Didn't check it before I flashed Finless 1.6 ROM, dont really have any blutooth accessories that i use, besides the fact that I could have possibly sync'd it with my Droid X...
      This is the specs provided from my **** auction:
      Specifications:
      • Chip: Rochip RK 3066, Cortex-A9
      • OS: Android 4.1 Jelly Bean
      • Display: HDMI OUTPUT(TV)
      • RAM: 1GB DDR3
      • Flash: 8GB Nand Flash
      • WIFI: 802.11B/G
      • 2.4G: Support 2.4Ghz wireless remote keyboard and mouse
      • Hard Disk: SUPPORT SD Card: 1GB-16GB ; Hard Disk: 1GB ~ 5TB
      • I/0 Port:
      • USB2.0 host X 1;
      • OTG micro USBX1 ;
      • HDMI OUTPUTX1
      But as it goes when you buy cheap things from China on **** they aren't always as advertied. Ie i really dont think i have 8GB NAND flash in this thing I think it's only 4GB.
      O and my WiFi is broken. and Yes i followed directions to the T when flashing... Yes i Erased the NAND (IDB) first.
          Yeah it's an mk808b did that NEW - MK808-B mini TV Player - Finless 1.5 Custom ROM
          and it works great, just wish it was more clear in the ad. I'm glad though cause it's nice to have it than not.
          Oh the world of flashing and the easily missed print, but thanks for looking out tho.
          Now to find out if anyone has an explaination on that other 4GB of NAND flash... You guys think it's hanging out with unicorns and the 1080P? some where over the rainbow?
            I tried the 808 roms at first 1.5 and 1.6 and they worked fine, minus Wifi.
            But since Fin doesn't seem to sleep he also released that 808b rom that weekend, and it works with Blutooth and wifi fine.
            All i'm saying is that they all flash well, you can flash the wrong one and still make it back.
            but good point on questioning the non android player's manufactures.
              still waiting to get mine, hopefully by then Fin releases 1.6 for the 808B and maybe a 1080 kernel shows up
