Hej all
I have an initial mx1 with the Stock rom 1080p loaded.
My mx1 seems to go into somekind of deep sleep / fredze after i leave my device on and not use it for some minutes/hours. I see the screen but my bt. Mouse + normal mouse can't awake it. Only thing to do is a , remove the power, reboot.
Sleep is turned off. YOu can see this in build.prop file
ro.rk.screenoff_time=-1
However I recall the OLD original ROM had an issue with shutting off USB. This might be your issue.
Best I can say is flash a newer ROM.
