Thanks Neomode. That was very fast. Ive seen references to the Omegamoon blog before when people talk about creating custom kernels, but i cant find the information that i need.
Ill Keep looking thanks.
{ { "1366x768p@60Hz", 60, 1366, 768, 85500000, 256, 58, 17, 1, 112, 3, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 4 }, 91, 1, OUT_P888 },
pi@raspberrypi ~/Desktop $ edidparser edid.out Enabling fuzzy format match... Parsing edid.out... HDMI:EDID version 1.3, 1 extensions, screen size 26x14 cm HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF HDMI:EDID found monitor S/N descriptor tag 0xff HDMI:EDID found monitor range descriptor tag 0xfd HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0 HDMI:EDID monitor range: vertical is 50-75 Hz, horizontal is 30-85 kHz, max pixel clock is 150 MHz HDMI:EDID monitor range does not support GTF HDMI:EDID found monitor name descriptor tag 0xfc HDMI:EDID monitor name is MotoAttach HDMI:EDID found preferred DMT detail timing format: 1366x768p @ 60 Hz (86) HDMI:EDID established timing I/II bytes are 00 00 00 HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101 HDMI:EDID parsing v3 CEA extension 0 HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1 HDMI:EDID found DMT detail timing format: 1366x768p @ 60 Hz (86) HDMI:EDID found DMT detail timing format: 1366x768p @ 60 Hz (86) HDMI:EDID failed to find a matching detail format for 0x1080i hfp:88 hs:44 hbp:-116 vfp:2 vs:5 vbp:16 pixel clock:0 MHz HDMI:EDID calculated refresh rate is 0 Hz HDMI:EDID guessing the format to be 0x1080i @24 Hz HDMI:EDID found unknown detail timing format: 0x1080i hfp:88 hs:44 hbp:-116 vfp:2 vs:5 vbp:16 pixel clock:0 MHz HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48|96|192 kHz, sample size: 16|20|24 bits HDMI:EDID found HDMI VSDB length 5 HDMI:EDID HDMI VSDB has physical address 1.0.0.0 HDMI:EDID HDMI VSDB has no extension fields HDMI:EDID adding mandatory support for DMT (4) 640x480p @ 60Hz HDMI:EDID adding mandatory support for CEA (2) 720x480p @ 60Hz HDMI:EDID adding mandatory support for CEA (17) 720x576p @ 50Hz HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023 HDMI:EDID best score mode initialised to DMT (4) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0) HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 43432) HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 45736) HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 45736 HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 36864 HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 45736 HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 45736 HDMI:EDID best score mode is now DMT (86) 1366x768p @ 60 Hz with pixel clock 72 MHz (score 5188835) HDMI:EDID preferred mode remained as DMT (86) 1366x768p @ 60 Hz with pixel clock 72 MHz HDMI:EDID has HDMI support and audio support edid_parser exited with code 0
[B]HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 45736[/B] HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 36864 [B]HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 45736 HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 45736[/B] HDMI:EDID [COLOR=#ff0000][B]best score mode is now DMT[/B][/COLOR] (86) 1366x768p @ 60 Hz with pixel clock 72 MHz (score 5188835)
There are currently 3508 users online. 4 members and 3504 guests.
