MK808 - USB LAN Gigabit Ethernet with SMSC75xx chipset and various drivers in github.
If that works on my 1.6 ROM then it is because the driver is in the kernel. I do not see that device as a .ko module in my 1.6 ROM. So no, it cannot be extracted.
Originally posted by Finless View PostIf that works on my 1.6 ROM then it is because the driver is in the kernel. I do not see that device as a .ko module in my 1.6 ROM. So no, it cannot be extracted.
Thanks for that info. Could you point me to a tutorial how I could build the module myself then?
Thanks very much,
herges
Originally posted by andrewott View Postis gbit lan really necessary over usb 2.0?
So yes for some of the HD content I have it stutters on 100 MBit/s in high bitrate sequences whereas with this adapter on the same laptop it works fine.
herges
Usb Wifi Adapter (tp link tl-wn722n)
Originally posted by 2dark4u View PostI can help to resolve this problem.
Wait I'll add this LAN driver to kernel with proper init's for You to test.
Im using MK808 with Bob 1.6 version and your latest kernel.
Ice
Plugable USB2 to Gigabit Ethernet adaptor on 2Dark4You latest ROM
Hi All,
Just wanted to let you know that it turned out the adapter I had was faulty and never got an IP address on a Windows or Linux machine either. Got a replacement for it and everything works fine now.
One question though, how do you check if the adapter is using 100 or 1000 Mbit speeds?
Edit: Never mind I found it in Chronozen's post "/sys/class/net/eth0/speed"
Thanks,
herges
mk808 lan trouble
hi guys
i am so happy to find this here.
i have trouble setting up lan connection with mk808 on my tv.
wifi works fine.
i want to fix this so i can watch xbmc.
here are pictures of how the settings are made on my tv.
i really hope you can help me solve this
thanks in advance guys.
rachel
i am using this usb to lan adaptor
http://www.kgg.co.th/thumb/thumb.php?fi ... mbsize=304
which i bought from this company
Event Planner & Organizer in Phuket, Bangkok, Thailand Phuket Event Company is a leading event planner and organizer based in Phuket, Thailand, offering award-winning corporate and private event services nationwide. EVENT PLANNING WE ORGANISE YOUR EVENTS IN PHUKET WITH METICULOUS ATTENTION TO DETAIL. Event Production Producing Unforgettable Events with Seamless Planning and Exceptional Attention to [...]
Message in a bottle
Hi you all!
I anxiously read ALL you posts.
I'm using Finless Bob Rom 1.6-[1080 kernel and boot img.].
I desperately need ethernet to work.My adapter is Logilink UAO158 using the damn' SMSC Lan7500 chipset.I'm not a superexpert like you all.Still,could you give me some advise on WHAT to do??
Thanks in advance,
N
P.s.Maybe already exists a Finless Bob Rom 1.6 with a suitable kernel??
Would your same instructions work for installing TUN.KO from 1.7 into 2.1?
Hi, Bob
I've been running your 1.7 on original MK808B only because vpn won't work on 2.1 which I think is because tun.ko is not present in 2.1. Can I use your instructions below to copy tun.ko out of 1.7 (assuming the file would be sitting in the file directory) and install it into 2.1?
If I've got your attention, another quick question: Any idea why bluetooth periodically shuts off and cannot be enabled until it is selected in settings, and then rebooted? After the reboot, it comes on, but not before that.
-Bob
Originally posted by Finless View PostHere is the kernel module for the 75xx
I tested that it will insmod into the kernel with no errors. But I cannot test your device since I do not have it.
Instructions for testing:
1) Download this ZIP file.
2) Unzip it
3) Put the file smsc75xx.ko on your sdcard.
4) Get ES File manager from Google Play
5) Make sure to setup root explorer and mount system RW in ES File manager settings.
6) Copy the ko file to system/lib/modules/ using ES File Manager
7) After it is copied long press on the file name and in the pop up menu select properties
8) Change permissions Read=check all boxes, Write=check first box When done permissions should be rw-r--r--
9) Get Terminal Emulator from Google Play
10) Run terminal emulator and type su
11) Respond to Super User YES to give permissions
12) Type the following: insmod /system/lib/modules/smsc75xx.ko
13) You should not get any errors.
14) To confirm the module is there now type: lsmod
This will list all kernel modules and you should see smsc75xx.ko listed.
15) Now go into settings and turn off wifi. Then plug in your device to either the full sized USB port or the OTG port. DO NOT use it through a hub yet! Direct to the port please.
Now see if your device works. If it does, I will give you a new boot.img that will auto inject the module for you.
There are currently 4509 users online. 2 members and 4507 guests.
