USB v1.1 ?
    USB v1.1 ?
    I have a slight feeling that the Wi-Fi of TV Sticks are built in USB v1.1.
    Wi-Fi work better with router set to 12Mbps, though max speed of 5Mbps to Internet, Network Share and DLNA.
    Someone received real speed more than 12Mbps?
    I read all the threads here, it seems that many have the same problem with Wi-Fi and USB RJ45 Adapter.
    Thanks in advance.
    Thanks in advance.
    I don't believe this is the case. Right now, here is my tests I just did.
    Desktop:
    TV Stick:
    (let me hook the keyboard back up to the stick :P)
    As you can see, the TV stick actually pulls better network speed than my desktop using a Wireless N DLink USB stick.
    BTW, I have flash installed, so I was able to run the speedtest through the Browser instead of using hte APP. I found the APP to be really bad on finsing a good Host to connect and test to.
      Thanks for clarifying firepong. I use MK802III, which your TV Stick?
      I can't more than 600kb/s (5Mbps).
        Mines the UG802. Basically the same thing with a downclocked processor (1.2ghz compared to 1.6 on yours).
          Built in USB 2.0.
          I tried firmware Minix G4 4.1.1 and not resolved. I suspect my G Router, just after try connecting to another router (N).
            BTW, I suggest you install flash and use the Speedtest.net website for the test. I've found the app to be lack-luster on picking a good server and having shitty Down/Up speeds. Even on my phone, it isn't working well.
