How to install app on external SD card?
    As below ,I have to install on interal memory ,not sd card ,anybody know how 2 mod it ,many thanks.
    Yes there is a Trick, you must make a Ext4 Partition on your SD Card.
    Then You need a Script thats merge the Internal App Storage with the one from SD Card.
    Will see that im finding this Script.
    Neomode
