SD storage Mapping inconsistencies.
    Not a big deal, but when I go into >Settings> storage, the external SD card is showing as SD Card with size and and available space along with internal storage and Nand.
    But when I use root explore it is not showing as External-SD off of root directory like the built in "internal storage" "sd card" does. I have to navigate to /mnt/external_sd to get to it from root explorer.
    I know in Linux that standard mnt's are normally shown in /mnt, but shouldn't the External_sd also be further mapped off of root directory like the internal "sd card" is mapped?
    My RAZR does this correctly. Off of root I have sdcard and sdcard-ext. There is no need to dig down into /mnt... to see the external card and contents.
    MK802III Runnin' the Fin v1.7
    Nothing??? Or am i doing something wrong.? Lol
      This is correct. They did not setup a sym link for external sd on internal sd mount. I planned to fix that but keep forgetting to.
        Thanks Bob for replying. That would be great if you could map that in your next build. Correcting what Rikoh didn't do. Which seems to be most of what your ROMs do in the first place. hehe.
        I am sure there is a startup script I could setup to do it, but I am not that versed in those things. I don't really want to put much more work into this one because I have a replacement on the way that hopefully will have a working wifi connection.
        I hope you don't mind, but sometime in the near future I would like to play around and slightly mod your startup animation to reflect it being for the MK802.(leaving your credits intact) Once i get some time and get that done I would like to post it if okay with you. Just a little tweak for us on the MK. I'll shoot a copy to you to let you look at it before I do anything.
