Change Internal with External Sd Cad
I've swap the external sd with internal by changing the mnt scripts on my N9770, but forgot the posting used as a point of reference. The only problem is that you must copy of the contents of the files.
I had CWM to preform this for me, but I believe there apps which will do this for you.....
play.google.com
Root External 2 Internal SD
Regards
There are currently 3729 users online. 5 members and 3724 guests.
