masheka, I think your the only one here that is interested. Are you willing to test? Understand I have no way to test and thus changes I make could brick your tablet. However you can always flash back using RKBatch tool. Do you know how to do that?
You will need to have the RK28 flash drivers installed. This wont be a simple copy update.img to the SDCard. The changes require use of a flash tool and that flash tool needs drivers installed.
Might you have the drivers installed already from possible previous flashes qwith the 10B?
If not I can make a kit with them to start with.
