10 d G3 *root* Rom
    10 d G3 *root* Rom
    Here is the Custom Rom for the Arnova 10d G3.
    Based on the Original Firmware. Removed unused App´s and Speed Up Fixes.
    Install:
    1. Download the update file for your device « ARNOVA_10d_G3_20121031.zip ». You can save it to the desktop of your computer for example.
    2. Connect the USB cable to your Arnova and your computer so that the ARNOVA is seen as an external hard drive (as normal).
    3. Copy the « ARNOVA_10d_G3_20121031.zip » to the root of the device. Do not place it into any folder of the Arnova, just to the root level of the device.
    4. Unplug your device safely as usual using the green « disconnect safely » arrow in the system tray.
    5. Once disconnected, go to “Settings” application on your tablet, then “About tablet” and finally go to “System update”. Then, you just have to follow the instructions on the screen and select the firmware “ARNOVA_10d_G3_20121031.zip”. Your product will restart. You must then go though the installation wizard. Not only will this process allow you to configure the basic settings of your player.
    Download:
    https://a170132.uranus.1blu.de//data...9e.php?lang=en
    Neomode
