I want to get a full backup of the (stock) tablet before trying a different rom...
PTAB7XC Custom Recovery
With all of my other android devices, I'm accustomed to using adb to push a custom recovery .img file to the device to set up CWM or TWRP. Is that not how it's being done on these 7" Polaroid tablets? If it is, where are the .img files available?
I want to get a full backup of the (stock) tablet before trying a different rom...Tags: None
Originally posted by waleslie View PostWith all of my other android devices, I'm accustomed to using adb to push a custom recovery .img file to the device to set up CWM or TWRP. Is that not how it's being done on these 7" Polaroid tablets? If it is, where are the .img files available?
Here's a link to a couple of CWMs built (I believe) by William Kleiman who used to be active in this forum: https://docs.google.com/folder/d/0B4...orcehl=1&hl=en Choose the folder named 'nandi' if your tab has 9 partitions and 'nandj' if it has 10. In each folder, you'll find a "recovery.img" which should be CWM 6.0.1.2
Re: PTAB7XC Custom Recovery
Originally posted by dolorespark View PostChoose the folder named 'nandi' if your tab has 9 partitions and 'nandj' if it has 10. In each folder, you'll find a "recovery.img" which should be CWM 6.0.1.2
Originally posted by waleslie View PostI'm using a Polaroid PTAB7XC. How do I find out how many partitions I have?
There are currently 3144 users online. 2 members and 3142 guests.
