Biggest concern with the mini PC is getting a suitable 240V power adapter in order to provide sufficient power to the device without causing it to go unstable, and possibly frying it in the process. What is a good recommendation for a good quality 240V power adapter? Also what are some good choices for a USB hub with an on/off switch?
Does the mini PC come with software that supports the playing of PAL format videos? Noticed that a recommendation was made for a ROM suitable for the MK802 III (Finless 1.7), does that directly support bluetooth, and is it using Android 4.1 or greater?
