I've created this cwm zip for adding cifs support to my Archos 80 Cobalt ROM but it should also work fine for my Cube ROMs
instructions
download the zip to the internal sdcard, do not extract
reboot the tab to recovery (i've included Petrus's reboot app in the system tray)
from recovery select 'install zip from sdcard' (scroll with vol +-, select with power)
select 'choose zip from internal sdcard'
navigate through the folders etc to find cifscwm.zip and select
scroll through the nos and select 'Yes -Install cifscwm.zip' and let it do it's stuff
select go back and then reboot systm now
Your done :-)
Thanks for this!
I am going give this one a try on my friends Cube U30GT h(to help with accessing a NAS)
I was wondering if its something that could be incorporated within your special ROMs?
