Help with ROM for Polaroid PMID80C
Hey there! I'm new on this, i mean, on the adroid thing, and i bought a few days ago a polaroid tablet. Its a PMID80C with a 1.3 Ghz processor, and a 512 mb in ram with 4Gb of internal memory. Its suposed to be rooted from fabric, and i'm trying to find ROM's compatible with this polaroid model, but i've not found anything about that, is there anybody who can help me with this?? thanks
Tags: None
hardware info
Originally posted by neomode View PostHello,
Please run Hardware Info on your Device and post the Report here.
Thx
Neomode
UNKNOWN PMID80C
SYSTEM (Android 4.0.4)
Model: PMID80C
Manufacturer: Unknown
Device: Nuclear Evb
Product: Nuclear_evb
Brand: INet
Android Version: 4.0.4 (Ice Cream Sandwich)
API Level: 15
Fingerprint: iNet/nuclear_evb/nuclear-evb:4.0.4/IMM76D/20120817:eng/test-keys
DISPLAY (764x600)
Refresh Rate: 59,8 Hz
Default Orientation: Landscape
Physical Size: 6,06" (15,4 cm)
Density: 120 dpi (Low)
Pixels Per Inch: X: 160; Y: 160,42
PROCESSOR (ARMv7)
Processor: ARMv7 Processor rev 2 (v7l)
Cores: 1
Max Frequency: 1200 Mhz
Instruction Sets: armeabi-v7a, armeabi
NEON Supported: Yes
MEMORY (353 MB)
System RAM: 353 MB
JVM Max Memory: 48 MB
Internal Storage: 613 MB
External Storage: 193 MB
FRONT CAMERA (1,3 megapixel)
Effect: None
Effect Values: None, Mono, Negative, Sepia, Aqua
Exposure Compensation: 0
Exposure Compensation Step: 1
Focal Length: 3.43
Focus Areas: (0, 0, 0, 0, 0)
Focus Distances: 0.10, 1.20, Infinity
Focus Mode: Auto
Focus Mode Values: Auto
Horizontal View Angle: 51.2
Jpeg Quality: 90
Jpeg Thumbnail Height: 240
Jpeg Thumbnail Quality: 90
Jpeg Thumbnail Size Values: 320x240, 0x0
Jpeg Thumbnail Width: 320
Max Exposure Compensation: 4
Max Num Detected Faces Hw: 0
Max Num Detected Faces Sw: 0
Max Zoom: 30
Min Exposure Compensation: 4
Orientation: 0
Picture Format: Jpeg
Picture Format Values: Jpeg
Picture Size: 640x480
Picture Size Values: 1280x960, 1280x1024, 640x480, 320x240
Preferred Preview Size For Video: 1920x1080
Preview Format: Yuv420sp
Preview Format Values: Yuv420sp, Yuv420p
Preview Fps Range: 5000, 60000
Preview Fps Range Values: (5000, 60000)
Preview Frame Rate: 25
Preview Frame Rate Values: 25
Preview Size: 640x480
Preview Size Values: 640x480
Prop Facing: Front
Prop Orientation: 0
Recording Hint: False
Rotation: 0
Smooth Zoom Supported: False
Vertical View Angle: 39.4
Video Frame Format: Yuv420sp
Video Size: 640x480
Video Size Values: 640x480
Whitebalance: Auto
Whitebalance Values: Auto, Incandescent, Fluorescent, Warm Fluorescent, Daylight, Cloudy Daylight
Zoom: 0
Zoom Ratios: 100, 106, 113, 120, 126, 133, 140, 146, 153, 160, 166, 173, 180, 186, 193, 200, 206, 213, 220, 226, 233, 240, 246, 253, 260, 266, 273, 280, 286, 293, 300
Zoom Supported: True
SENSORS (1)
MXC622X
Vendor: MEMSIC
Range: 2.0
Resolution: 0.15322891
Power: 0.005 mA
OPENGL 1.X (Mali-400 MP)
GENERAL
Renderer: Mali-400 MP
Version: OpenGL ES-CM 1.1
Vendor: ARM
LIMITS
Texture Size: 4096x4096
Texture Units: 8
Viewport Size: 4096x4096
Modelview Stack Depth: 32
Projection Stack Depth: 32
Texture Stack Depth: 32
Lights: 8
COMPRESSED TEXTURE FORMATS
ETC1, Paletted
EXTENSIONS
GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_matrix_get GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_point_size_array GL_OES_point_sprite GL_OES_texture_npot GL_OES_query_matrix GL_OES_matrix_palette GL_OES_extended_matrix_palette GL_OES_compressed_ETC1_RGB8_texture GL_OES_EGL_image GL_OES_draw_texture GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_framebuffer_object GL_OES_stencil8 GL_OES_depth24 GL_ARM_rgba8 GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_OES_texture_cube_map GL_EXT_discard_framebuffer
OPENGL 2.0 (Mali-400 MP)
GENERAL
Version: OpenGL ES 2.0
Vendor: ARM
GLSL Version: OpenGL ES GLSL ES 1.00
LIMITS
Texture Units: 8
Vertex Textures: 0
Combined Textures: 8
Renderbuffer Size: 4096x4096
Cubemap Size: 1024x1024
Vertex Attributes: 16
Vertex Uniforms: 256
Varying Vectors: 12
Fragment Uniforms: 256
VERTEX NUMERIC PRECISION
Int: [-2^24, 2^24]
Float: [-2^127, 2^127], 2^-23
FRAGMENT NUMERIC PRECISION
Low Int: [-2^11, 2^11]
Medium Int: [-2^11, 2^11]
High Int: Not available
Low Float: [-2^15, 2^15], 2^-10
Medium Float: [-2^15, 2^15], 2^-10
High Float: Not available
ETC1
EXTENSIONS
GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer
GRAPHIC MODES (RGBA 32bit)
RGB 16bit (565)
RGB 16bit (565), Depth 24bit, Stencil 8bit
RGB 16bit (565), Depth 24bit, Stencil 8bit, Samples x4
RGB 16bit (565), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
RGBA 16bit (5551), Depth 24bit, Stencil 8bit
RGBA 16bit (5551), Depth 24bit, Stencil 8bit, Samples x4
RGBA 16bit (5551), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
RGBA 16bit (4444), Depth 24bit, Stencil 8bit
RGBA 16bit (4444), Depth 24bit, Stencil 8bit, Samples x4
RGBA 16bit (4444), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
RGB 32bit (888)
RGB 32bit (888), Depth 24bit
RGB 32bit (888), Depth 24bit, Stencil 8bit
RGBA 32bit (8888)
RGBA 32bit (8888), Depth 24bit, Stencil 8bit
RGBA 32bit (8888), Depth 24bit, Stencil 8bit, Samples x4
RGBA 32bit (8888), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
FEATURES (26)
GRAPHICS
OpenGL 2.0
ANDROID HARDWARE
android.hardware.camera
android.hardware.camera.autofocus
android.hardware.camera.flash
android.hardware.camera.front
android.hardware.faketouch
android.hardware.location
android.hardware.location.gps
android.hardware.location.network
android.hardware.microphone
android.hardware.screen.landscape
android.hardware.screen.portrait
android.hardware.sensor.accelerometer
android.hardware.sensor.compass
android.hardware.telephony
android.hardware.telephony.cdma
android.hardware.telephony.gsm
android.hardware.touchscreen
android.hardware.touchscreen.multitouch
android.hardware.touchscreen.multitouch.distinct
android.hardware.usb.accessory
android.hardware.usb.host
android.hardware.wifi
android.hardware.wifi.direct
ANDROID SOFTWARE
android.software.live_wallpaper
GOOGLE
com.google.android.feature.GOOGLE_BUILD
Created with Hardware Info 2.1.0
There are currently 3484 users online. 3 members and 3481 guests.
