I am new to PC sticks. Before buying my 1st (and hopefully the only for quite some time),
I would like to know which stick has the most reliable WiFi hardware. (In terms of % probability may be)
I read about the quick fixes and mods, but some devices have the contacts shortened on the PCB itself.
Thus no mod can save it. I'm not planning to use a usb/ethernet adapter as well.
My current short list is: iMito MX1, UG802, MX808(B) [Budget approx $50-60]
My usage is pretty basic: Youtube, Media Player, Basic browsing.
I also hear that the Blue PCB - mx1 are a better breed which you get from Geekbuying.
[edit]
Oops. Geekbuying sells red pcb mx1 too?
link 1
link 2
[/edit]
Anyone second that?
While i'm on the subject i'd like to take the liberty to ask another question.
I plan to use the Bluetooth speakers for audio while watching movies.
For the BT audio lag is there some player (app or stick) which can allow me to set the audio delay?
I hope to cancel out the lag some how. Possible?
Thank you for your time.
Regards
Rishi.
