Logitech Webcam C310 problems under MX1 Finless 1.5 (kernel1080)
    Hi all,
    I'm having problems using a Logitech Webcam C310 runnning under MX1 Finless 1.5 Firmware (1080p beta kernel).
    Apparently,darkness from armtvtech forum have the same camera working properly with the MX1 and the same kernel.
    If you think you can help, can you please have a look at http://www.armtvtech.com/armtvtechfo...hp?f=76&t=1136
    Thank you
    I'm also having problems with the C310. It can hear my voice but any apps that use video will quit. I worked fine with the stock ROM.
    Originally posted by jefflessard View Post
    Hi all,
    Thank you
