Next7P12 ROOT??
    Next7P12 ROOT??
    Ok, so first off, I'm far from a noob when it comes to rootin but when it comes to this tablet, I'm lost. I saw the ROM Finless posted and it clearly states on how to flash it BUT I have no idea if it will work on the N7P12 YF0912...I have yet to find out how to root the dang thing or if its even possible...I have scoured the interwebs for an answer to no availability. Can ANYONE be so kind as to lend some kind of info on this matter? All I want to do is simply root it to have the Play Store loaded in with no issues. I can deal with a lag and such. I guess my real problem is, when i try and follow the instructions it says to reset it with the pin hole but THERE IS NO PIN HOLE on the thing anywhere..can anyone help me out?
    If you have no pin hole then you have one of the new AMlogic based devices!
    As of now there is only one way to root it using as 3G dongle. See the discussion here:
    http://www.freaktab.com/showthread.p...ogic-root-WORK!
