How to customize key mapping with MK808 custom ROM 1.6?
Hi, I have an MK808 dongle, which flashed the Finless custom ROM 1.6,
and
a fly-mouse remote control.
The remote with several keys working like volume up/down, arrow keys, however, it's not recognized as a external keyboard, some other buttons don't work.
As I tested it on my linux, it sends general keyboard scan codes, I want to enable the key functions like HOME, MENU, MUTE.
I have tried to edit the .kl files under /system/usr/keyboardLayout, (Generic.kl / rk29*.kl) but seems no effect...
Where I can edit the internal key mappings, or it's not possible?
I am moving this to MK808 forum and will leave a 1 week redirect from here.
Thanks frodo,
by modifying Generic.kl, HOME & MENU works, but MUTE doesn't, either I set it to MUTE or VOLUME_MUTE
scan code 113, normal like in all these .kl files.
so does it mean that 4.1 doesn't have the key function MUTE??
what about yours?
On the Logitech K260 wireless keyboard the mute key (special key) doesn't work. Don't think Android 4.1 recognises the mute key, maybe Android 4.2 does?
Strangely when the stock ROM was used on the MK802 IIIS the mute key did work, not sure how that is possible . Maybe the manufacturer (Rikomagic) has added in the support for Android?
