U10GT2 - TR810v25 motherboard
    Hello,
    I own an U10GT2 - with TR810v25 motherboard.
    RK2918, RK-610g, 1024*768 8inch display, 8GB flash, internal HSUPA module,etc
    I tried to flash new firmware and after that I can't see anything on the screen. I was stupid I didn't took any backup .
    I remember that I tried to flash cwm with touch support because it hasn't volume buttons. No success.
    Now I have tried alot of firmwares without success. Can't see anything.
    I tried also rooted firmware from U9GT2, but connecting with USB and Wondershare MobileGo I see picture on my PC monitor without a way to do anything. Probaply the touch chip is different.
    Because I'm not expert with firmware I ask for your help.
    Thank you in advance.
    Re: U10GT2 - TR810v25 motherboard
    I'm guessing that's a cube tablet, if so see if there is a firmware available on the cube website
    900Supersport
    freaktab developer
      Yes, that`s a Cube tablet.
      I have downloaded the firmware, flashed but without success.
      Have also tried U9GT2, nothing.
      Because I don`t see anything I can`t use cwm.
      Any idea?
      If I post the link from the firmware is it possible to make it rooted, make by default to open in adb mode and make by default hdmi as primary display?
      Asking too much?
      Thx
        To be honest I've not worked any rk29 ROMs. I may be able to root but that's likely the limit with no way to test.
        Was the from you flashed that caused the issue for the u10 or where you trying something else?
        900Supersport
        freaktab developer
          Have tried to flash cwm with touch support.
          After that chaos.
          Tried also other firmware but nothing.
            There's a thread on hear somewhere by finless about how he managed to fix a similar issue. He ended up flashing many images until he found one that would reload the screen drivers.
            900Supersport
            freaktab developer
              I will try a post there also.
              I have tried his rom also, nothing.
              Thx
