I'm running UG007 with Finless 1.5 for MX1, but this also happened with the default ROM. The only thing I can think of that is special with my setup is that I use Mount Manager to mount an SMB drive to /mnt/sdcard/smb/. Are anyone else having this problem or know what I might be doing wrong?
UG007 Internal Storage Freeze
Hi guys. I occasionally experience something like a freeze on the internal storage. The problem manifests itself as so: All file browsers will either sit with a blank screen saying "loading" (something to that extent), or crash at start up I've tried ES, Astro, Explorer and Solid Explorer and all do the same thing. A reboot fixes the problem.
I'm running UG007 with Finless 1.5 for MX1, but this also happened with the default ROM. The only thing I can think of that is special with my setup is that I use Mount Manager to mount an SMB drive to /mnt/sdcard/smb/. Are anyone else having this problem or know what I might be doing wrong?Tags: None
There are currently 2616 users online. 3 members and 2613 guests.
