Rom for MK809II?
    Originally posted by mcc05 View Post
    Take a look here for how to get the kernel from the img file...
    Wied that others say the Wifi doesn't work after Finless 1.5 , mine works fine, are they sure they have 809II and not 809, as uestebang above states it doesn't work..
    A boy in xda's MK808II thread says that he has wi-fi problems after flash.
    Mine does not work at all, so I have bigger problems
      Over in xda was a post be me, my MK809II works just fine with Finless 1.5 for MX1/MX2 and "CWM-based Recovery for Rockchip" flashed lasdt night.
      Have you tried going back to stock?
        I did not flash it yet, because my MK809II does not work.
        In the box I found a 1A ac adapter, maybe it's not powerful enough.
          i did flash finnless rom and the cwm-recovery image successfully on my mk809 .
          but first of all i had to do a hard - reset like described here: http://www.mk809.com/cs102/UploadFil...nstruction.zip
          flashed over the the recovery stock-rom, than finless rom and than finaly the cwm-rom .
          All is working but Wifi.
          Saw the posting about the kernel.img dump and reinserting this into the finless rom, but had not yet a chance to get this done. Maybe some can step in here?
          thnx in advance.
            Now my 809II is working and rooted.
            Which recovery did you flash? Generic os some specific?
            I think that tonight I will try to flash mine.
              I flashed the one from here : http://androtab.info/clockworkmod/rockchip/
              RK3066 version.
                RK3066 version.
                ok but... which one?
                Specific (for example MX1) or generic?
                  generic RK3066
                    generic RK3066
                    there is a specific one for mk809II now
                    if i may ask how does one flash such an img
                    or can i do it by renaming update.zip and put it on my sdcard
                      ok swapped to the mk809II one np
                        generic RK3066
                        sorry if you think that it was a dumb question, but since here we are installing the x1 rom, I was simply not sure if we could install x1 recovery.
                        ayway, I flashed finless 1.5 x1 rom and cwm.
                        everything working, wi-fi too, from first boot.
                          No question is a dumb question! Glad its all work for you
                            does anybody have problem in using cmw after flashing MX1 rom?
                              can anyone point me to a thread about installing the clockworkmod generic 3066 on mk809 II?
                                Can someone that still has original rom check the real max working cpu frequency?
                                After flashing iMito MX1 rom even if I can set 1.6GHz, it does not go over 1.2GHz.
