this rom is based on the work of rainlake (thanks), this rom wasn't really finished, and not much was happening, so I forked this and started cleaning things up and getting it to the point I wanted.
This rom is using a custom partition table so erase your nand first, data partition is removed, one big userdata is used as seen on modern android phones, this means internal storage is only accessible with mtp, mass storage will only show external sd card.
CWM is flashed to recovery, reboot to recovery for access.
It has the regular cyanogenmod features with,
Rockchip Settings,
Navbar buttons for vol up/down and power (long press for power menu),
Ethernet support.
Kernel will default to 1080p if available otherwise use the next available resolution.
Just extract and run rkflashtool, erase idb and then run to flash.
It will boot CWM the first time, choose reboot and just wait. It will also reboot the first time when creating filesystem on empty partitions.
Direct any bugreports and/or feature requests to me, i'll keep developing this if any interest exists/or until I lose interest
Download:
http://goo.gl/YzKae
Source will be available at the following adress when I have the time to upload, only device, vendor and kernel is available right now,
