Putting a heatsink directly on top of the chip and on the ram did not help.
Im trying to do some tests lowering the CPU speed.
I have installed the latest oficial rom rooted, and installed "android Tuner free"
Changed the governor to performance, and changed the CPU to performance and 816Mhz, we will see how it goes for a few days. I have runned Antutu Benchmark and the score decreased from 8600 to 7180 score (this 7180 score is kind of near of what you get on an MK808 device)
if any of you are experiencing constant random crashes, reboots, freezes while playing or surfing, please posts your results,
i installed cyanogenmod 10 on the device, which has a non working wifi, and experienced crashes also so i dont think this issue is software related.
thanks
