Got an Imito a couple weeks ago, I really like it, but I'm starting to think there's an issue with the video / display output stuttering (juddering?) in all applications, ie. not being 100% smooth.
I was watching Netflix on the Imito and scenes with lots of motion made it quite obvious. The problem though is it also happens not only on video output, but in rendered content.
Now here is a really simple test you can do and I would REALLY appreciate it if you'd take the 2 minute and do it:
- download angry birds HD (free) from the play store
- start it until it gets to the "PLAY" button (to start a game) -- don't push it
- look at the red angry birds flying in the background, they should be 100% smoothly moving
- here, every 1-2 second they "jerk" or "judder" (ie. skip a few frames), more obvious if they're moving fast, do you see it???
Here's what I've done, and what I'm running:
- Imito MX2, Finless 1.5a 720p rom
- Display output 720p/1080p same thing (in Android display settings)
- TV resolution 1080p x 60hz
- Killed ALL background apps with System Tuner (thought it might be something waking up each second)
- Obviously turned off all TRU-MOTION ie. frame imterpolating crap on TV -- it's as direct as it can be
- Turned off wifi + bluetooth
I don't know what else to try... Please try the Angry Birds Test (as its a simple one) and tell me if you have the same issue! (Imito Mx1 or Mx2)...
Thanks!
