HOLY COW!
I will look into this but no gaurentee... It could need a lot of code changes if the functionality is just "missing" in framework, services, etc. If the code is there and just not working right, this might be something I can fix. I will have a look soon.
Thanks for the heads up.
Hey Bob,
You are making me want the Neo X5 too. Last time you recommend something this much was the imito mx1 and it was a pretty nice unit. Hopefully I'll get the X5 soon. Don't forget you could always add xpad.ko and other controllers support to the ROM.
Thanks for the heads up,
Rivers from YouTube somecooltech1
As for my reccomendations. Like the saying goes "Opinions are what you pay for them". So please, what I think is a good device doesnt mean anything really.
Like most people here, no one really is an expert AND these RK TV devices are new. They are going through development and getting better with time. The reason I was able to break into the ROM scene with these is because I have done hundreds of RK ROMs for tablets. So it was an easy transtition to these devices for me.
BUT IN NO WAY am I a "user" expert with TV's, different video formats, all of the input devices that can be used, etc, on these devices!!! Could anyone be truely? So I am just stating...... just because I like something, does not mean other users expecting something other than what I like or find good, is true for everyone.
Boot time?
Finless
I'm thinking of using a Neo X5 in my car. But I need to find a way to either keep it powered all the time or if it boots quickly enough find a way to trigger it to power on with my ignition. Since you have one would you mind testing how long it takes to boot from completely powered off? Also could test from being on then using the remote to power it off then on. The manual says when you use the remote it goes into to a “sleep mode” is this true? Is it different then hold the power button in to power it off? THANX!
I am not a DEV just an enthusies and user. I also have an imito x1 and much prefer the build of this unit.
Welcome to the board and keep those great reviews coming
Originally posted by mrfunnyman View PostI have not clocked the actual time but once setup from complete power-off I would say it take approximately 30-45 seconds to completely load up. When you put into sleep and return the cycle takes 5 seconds or less. Also for this sort of application you may want to consider a sleeker control instead of the remote because I would say overall the remote is significantly lacking and has limited controls beyond power, volume and some basic video controls (play, stop, etc). The good news is there are many bluetooth and 2.4mhz wireless units that are working with most features including sleep mode etc.
Originally posted by nettech_gt View PostTHANX! for your response. Is the only way to put it in sleep mode and wake from sleep with the remote/ BT keyboard? Any ideas on how I might be able to wake the Neo X5 when I turn on my car? THANX!
Re: HOLY COW!
Hey way to go, Finless! Glad to hear it gives a good impression. After my mk808 I was looking at the minix. I'm getting a bit tired of all those no brand chinese crap products. They seem ok, but then you discover things like bad WiFi reception or cooling is bad designed.
I'm especially interested if this box is more stable and faster than the mx808. And ac3/dts will hopefully work in the future. Guess its an android issue. But this hardware is at least ready for it. I will follow you with interrest!Last edited by MaVe_64; 01-27-2013, 11:30.
Originally posted by jlcd View PostHi Bob,
I connected the Minix Neo X5 using ethernet, but I get a "No internet connection" message in the status bar while there´s in fact internet connection. Some applications got confused and refused to work because of that. Is there any solution for this?
Yes I am seeing this issue even on one of my tablets. So it appears to be some kind of Android issue.
However try this. Once ethernet is on, turn off wifi. Then go into to MORE and setup a wifi hotspot. This seems to tell Android to use ethernet and that wifi is on but is supporting a hotspot so it ignores it being off.
Originally posted by Finless View PostYes I am seeing this issue even on one of my tablets. So it appears to be some kind of Android issue.
Just to add, all this on MX1
Thats odd.... try setting a static IP for ethernet. Or turn of wifi and then reboot. Then try hotspot.
I do not remember exactly what I did but it stopped having some things report no ethernet even though the status board still said no ethernet.
My Yuandao tablet does not have this problem so I am going to dig into services and see if I can figure it out.
There are currently 3377 users online. 2 members and 3375 guests.
