MK808-B "V1 Clone" - Finless 1.6 Custom ROM
    UPDATE 1/29/2012
    Based on testing I consider this ROM no longer a BETA. So this is the launch version now of 1.6 for this clone.
    __________________________________________
    OK folks here is my MK808B 1.6 Custom ROM ported for the MK808B "Clone".
    My Beta 1 was missing some wifi modules and other sneaky SHIT they did in init scripts to try to hide what this wifi chip is! I think this is more HACKER SHOP than a real ROM shop based on what I found. STUPID if you ask me!
    If you want to read about BETA 1, here is the closed post:
    http://www.freaktab.com/showthread.p...ustom-ROM-BETA
    Note from BETA 1 which still apply:
    Whatever company is making these clones, they are security locking the kernel.img so it will only boot on exact hardware! Same with the new UG802 Clone! This sucks because it will not allow me to test boot the ROM except with my original MK808 kernel.
    Also please help with the readme.txt for flash mode instructions. Since I do not have one of these there maybe better ways to put it into flash mode. The current readme is following my MK802 instructions.
    So you folks with the MK808B Clone can try this ROM and provide me feedback for improvements.
    ROM DOWNLOAD -> MK808B "Clone" Finless 1.6 ROM (221 megs)
    35 views and a many downloads....
    No feedback from anyone?
    I am dying to know if it works please
      downloading, will report once flashed, within hour, thanks for your work in advance
        Cool! Thanks.... I wont be back for about 2 hours so take your time.
          worked flawlessly, WIFI & Bluetooth both works, Root works, Reboot not working
            Re: NEW - MK808B "Clone/FAKE" - Finless 1.6 Custom ROM - BETA 2
            Great news! I have some MK808s en route from China, & it's nice to know thanks to Finless Bob's efforts, I won't own white elephants.
            Thanks, Finless!
            Sent from my Nexus 7 using Tapatalk HD
            MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
              bob thank you very much, now I start to download ... I mention shortly the results
                Hi. Thanks Bob. In my MK808 Clone/Fake:
                Wifi--> Work
                Bluetooth -->Work
                Reboot --> Don´t work, superuser denied
                Ethernet--> Please ADD to your next Custom ROM, wired is more better than Wifi!!!
                Thanksssssss
                  error
                  when i flashed the rom i plug it on the tv it ve a android logo and reboot once .after reboot i just ve two linux logo at the left corner,pls help
                    Thanx. Now I finally got my WIFI to work...or at least I can turn it on. Now I have problem with keeping it connected. Ideas ?
                      Same for me too.
                      Sorry if this is a noob statement but I have no idea how to flash back to the original firmware from here.
                      Can anyone help?
                        Hello, proven performance with this ROM MK808. Ok Bluetooth, WIFI Ok, but sometimes if I'm either browsing or using data packets are lost, it may be because of the intensity of the WIFI, I'll keep trying.
                        Bob, thank you very much for your time and dedication.
                          Odd the reboot app is not working! When you first run it, you should get asked for permission from SuperUser. If you click accept, the reboot APP should not have SU permissions! Did you guys get that prompt and answer yes?
                          Glad I got wifi and BT working finally. Now I can do some cleanup, tweaks, and make a real non-Beta ROM
                          Thanks to those that took the risk and time to test it
                            All I'm getting is 2 penguins.
                            And would never having taken the risk if it wasn't for the fact that your development is so good. I'll happily take the risk again.
                              What do you mean 2 penguins? You mean this happens when you use the reboot APP?
