MK808 Gameloft fix?
    MK808 Gameloft fix?
    How can i apply the gameloft patch to the MK808.
    I have bought several games that get stuck in a boot loop as Gloft is not recognising the MK808.
    I have also bought a wireless GIOECK VX-1 for £12 that works brilliantly out of the box on Dead Trigger and ShadowGun.
    Please can someone point me in the rite direction as i was up till 4am trying different things.
    Cheers,
    Si
    Cheers,
    Si
      Re: MK808 Gameloft fix?
      You need to edit framework.jar, or find one that has already been edited.
      900Supersport
      freaktab developer
        i have no idea what to do? I Flashed the infected rom, all gameloft games work although the screen is a stretched image.
        I am also struggling with usb host and joystick centre.
          If the gameloft games work then you don't need a gameloft fix.
          900Supersport
          freaktab developer
            I need a fix for Finless Rom, im using infected rom and as i stated before infected rom is a stretched image.
              If Bob doesn't have time to look into this I can have a look. I would need a copy of framework.jar from /system/framework.
              Sent from my U30GT MINI using Tapatalk HD
              900Supersport
              freaktab developer
                I'm not trying to hijack your thread, but I think this falls in line with some of what you're doing. I have a PS3 controller on my MK808 via USB (assume all gamepads are treated the same) and I too can play dead trigger and shadowrun just fine. The problem comes from controlling gameloft games. As the mk808 doesn't have bluetooth so the sixaxis app won't load a driver, and since it also doesn't have a touchscreen BTUSB app states no touch panel and closes. I can run the gameloft games, I just can't use my gamepad/controller. If someone has a way to trick sixaxis or some other mod we can do that would be awesome. FYI - finless rom 1.6 with 2dark4u 1.4 kernel.
                Sent from my MK808 using Tapatalk 2
